Possible new car
Hello all. I am looking at a 2004 Vanden Plas. I’ve read the common issue threds but they all look to be a few years old. Anything I should look for? And do you think $6000 is a good price for 98k miles on it? It just had the rear shocks replaced as well as a new thermostat housing. I already own an 86 Vanden Plas but it’s a completely different cat than the 2004.
Hi, I am a happy owner of 2004 VDP for 2.5 years. Mine had originally 47K miles and I paid quite multiple of what Jhillzoom is quoting.
Car has factory airsuspension. This is not a daily driver, rather a garage queen. I do not drive it in winter too much sand and salt on the road.
I had to replace headliner. I knew that going in.
During my ownership following was done:
Spark plugs and coils replaced in first three months of ownership; Car threw missfire code, I replaced all eight, as long as I am there.
Replaced aircompressor seal was giving me plausability error.
Rear collision sounder.It stopped working I took rear shelf off when I was replacing original audio system with Android head unit. While at it I did replaced sounder and now it is working fine.
Changed transmission oil, filter-pan, mechatronic sleeve and transmission slevees, fuel filter; no indications, just PM.
Ah, yes windshield washer screen: failed first inspection: winshield washer was not working due to clogged pump screen
Fluids: rear differential; engine coolant; brake fluids, engine oil.
Replaced break pads 3 months ago.
I will have to rebuild CA and related components all 4 corners. All rubber bushings are split but are holding for now. I covered ball joints with new rubber boots, I guess, to prolong agony. I was hoping to work on CA's past winter, but something else came up.
For 20 years old car I think I am doing good.
Every old car is different, even if you think you have al history..
ragman1171
05-24-2016 11:30 PM
