Possible Suspension Problems
I HAVE THE SAME EXACT PROBLEM BUT ITS NOT THE AC COMPRESSOR AS YOU GUYS MAY THINK UNLESS ITS ON WITH THE AC BEING OFF.... My car has been doing the same thing and a horrible feeling that you are experiencing . It happens when I first start the car but then goes away.. Also its sporadic as well. In my mind I have been wondering if the cold weather might have something to do with this as it has begun to get cooler here in NYC ... I haven't even bothered checking it out because I know they will try to rob me and in my mind its not that serious .. But I would love to know what the hell it is so if anyone figures it out... PLEASE LET ME KNOW
Hey jah I just noticed something... Not sure what it means though. I noticed as I started my car just now after sitting over night that the noise was present and as I pressed on the brakes while still in park the noise who stop and as I let go it would start up again? Now I'm not sure what if anything that means but maybe one of the service techs in here may have come across this issue before. Also I noticed today that the front end seems a bit low sitting parked although it looks fine once started. Maybe it's me being paranoid ? Who knows. Any input would be great !!!
i bit the bullet and swallowed my pride and brought her in for service today.... I should get a report tomorrow . I couldnt take the noise anymore and coupled w the suspension to low message I said to myself let me just drop it off and see what they tell me.... Ill let you know tomorrow what they tell me jah.....
Received 2,194 Likes
hey jah i just noticed something... Not sure what it means though. I noticed as i started my car just now after sitting over night that the noise was present and as i pressed on the brakes while still in park the noise who stop and as i let go it would start up again? Now i'm not sure what if anything that means but maybe one of the service techs in here may have come across this issue before. Also i noticed today that the front end seems a bit low sitting parked although it looks fine once started. Maybe it's me being paranoid ? Who knows. Any input would be great !!!
cheers
I have done absolutely NOTHING to the vehicle except add a video module to the front nab screen and that was done months ago.... The dealer just called me and said NPF no problem found but of course its 50 degrees out today so its a bit warmer. I will go get the car today and bring somewhere else to have that checked out....
yes i did and his response was "its just the air suspension compressor filling up the shocks"? ummmmm what????? i don't buy it because like I said as I push the brake the noise goes away. Now I explained everything to my cousin who is a certified bmw service tech and without telling him what you told me his answer was "a vacuum leak at the booster" which is kinda similar to what you said.... and this is without even looking at the car and me just describing what the issues I'm having are
during a conversation w someone who turned out to be a mercedes tech I was told this yesterday..... "If I having a leaking shock and the pump is struggling to fill it up the pump will make noise from over working itself".. As far as the noise going away when I press on the brake his response was " well it could be that the air compressor is connected in some way to the brake booster" i forgot his exact explanation but it sure as hell sounded good... any service techs in here that can help out in deciphering what I'm trying to say? loll I'm sorry i was just overwhelmed last night....
I can promise that the compressor is not tied to the brake booster. Why would it be? The compressor gets louder as the pressure in the tank increases. It is working harder to put that last 50 psi into the tank.
The system first uses the tank if the press is sufficient, It then turns on the pump. after the system need for air is satisfied it will then fill the tank. This is usually done at road speed to minimize the noise.
What happened to the brake booster leak?
Jsedita74 (12-16-2011)
