Priority Warning
Received 6,361 Likes
Sure the car is legal. Here's the UK rules (which seem similar to NZ):
https://www.gov.uk/importing-vehicle...al-recognition
Besides, in the PC-Correct UK it might be considered (Ethnist?) to ban a language.
I have 3 Jap imports (in NZ) and the Jap indigenous cars (Hondas) can't be changed.
Playing with my X358, the Display language setting only affects the main display not the odometer screen. (My odometer is English).
Another thing, (radio frequencies), I don't have a Region setting in the Audio Setup (as Partick doesn't), yet my frequencies are not Jap ones.
I suspect the Jag specialist my dealer used, must have replaced the entire relevant software. Though X358 could be different.
And as an aside, I suspect Japan doesn't salt it's roads. Be proud of your Jap import !
Yoosey, would you mind sticking your car model in your signature?
Priority Warning
I am seeing this warning.on my Japanese Import which is not yet converted to English
1. Does anyone know what it means or can translate?
2. Is there an easy way to change language to English, I managed it easily enough on the Radio although one could never have guesed which buttons to press.
The car drives ok but the Nearside Front suspension definately need looking at.
Priority Warning
Priority Warning
A quick search yielded this...........................................
https://www.jaguarforums.com/forum/x...isplay-190553/
Either a forum or internet search.
bob
bob
ChrisMills (08-06-2018)
Try this:
Display language
To change the display language, switch the ignition ON while pressing the ML/km switch. The trip computer will display the current language. Press the ML/km switch repeatedly to cycle through the available languages. Once the correct language is selected, press the A/B switch. The new language will be selected after a delay of three seconds.
Display language
Thanks v. much. I got the following from an old post and it worked a treat:
1. push m/km button
2. stay on that button & turn ignition switch to position 2
release button and push again
3. when language change appear press A/B and scroll through until you come to English.
Worked a treat and and my Priority Warning was fixed by 0.5ltr of coolant and there was me panicking.
1. push m/km button
What now? Where's that come from???
Ha! I spent a while with Japanese alphabet, just for fun and that lead nowhere.
Then I compared my Jap manual with the English one (Jap P4-12 = Eng P94!) and determined Engine Coolant.
Then I saw the Language selection.
By that time, you guys were WAY ahead of me! Cheers and glad it's sorted.
1. push m/km button
1. push m/km button
nasa25
10-13-2015 07:11 PM
slmskrs
11-12-2013 02:08 AM
