Problem with Air suspension...XJR..help
Guest
Posts: n/a
Hello...
My XJR has air suspension problem. One morning the car just was down and doesn't want to go up. If some one had the same problem I would like to know how to solve it. Or if anyone has any trouble shouting info for me it would be great.
Thanks.
Thanks.
Received 2,193 Likes
YOUR CORRECT kEN, YOU NEED WDS OR IDS TO LOOK AT AIR SUSPENSION AND THEN RUN THROUGH TESTING. cOMMON PROBLEMS ARE INSUFIECIENT AIR SUSPENSION PUMP. OPERATES BUT NOT ENOUGH PSI FAST ENOUGH TO FILL THE RESERVOIR AND LARGER FRONT AIR SPRINGS, FOLLOWED BY A BAD/LEAKING SPRING, THESE ARE THE MOST COMMON FAILURES, AND IF YOU DRIVE IT TO THE DEALING DEFLATED, YOU MAY END UP NEEDING NEW FRONT AIR SPRING ANYWAY DUE TO DAMAGE
ORIGINAL: Envy337
Chill out with the caps.
