Problem w driver side window
Old 06-07-2011, 04:16 PM
Jsedita74's Avatar
Default Problem w driver side window
Now all of a sudden the window refuses to go up and down...... all the other windows work but not my window.... Is it time for a new master window switch or can this thing be fiddled with?
Old 06-07-2011, 05:59 PM
amcdonal86's Avatar
Try taking the switch out and cleaning the contacts.
Jsedita74 (06-07-2011)
Old 06-07-2011, 06:23 PM
Jsedita74's Avatar
will try this wk because its an intermittent problem. I wanna ask you when you push the switch up or down do you feel a bit of a click to indicate you have activated the one touch operation? I feel it in only 1 of the 4 switches and am taking an educated guess that they are supposed to click.. Please confirm if possible... Also what entails in removing the Master Window Switch? Do I have to remove the door panel? I am hoping you dont .....
Old 06-07-2011, 06:57 PM
jahummer's Avatar
Received 2,387 Likes on 1,494 Posts
Yes there is sort of a click you can feel. Just take the armrest off by removing the screws underneath it. Use some electronic contact cleaner. Could be dirty or could be worn.
A new switch pack is about $200.
Old 06-07-2011, 07:43 PM
hlgeorge's Avatar
This happened to my car and replacing the switch pack was the only fix for it.
Old 06-07-2011, 08:07 PM
amcdonal86's Avatar
You may want to try "exercising" the switches. Just push them up and down over and over again for a couple minutes at a time, and over the course of a couple weeks. Mine seem to have fixed themselves that way.
The one I'm having trouble with is my map lights! The button connections seem to be dirty or something?
Old 06-07-2011, 09:01 PM
Jsedita74's Avatar
Can the individual faulty buttons be individually replaced?
Old 06-07-2011, 09:13 PM
jahummer's Avatar
Nope....
Old 06-07-2011, 09:39 PM
Jsedita74's Avatar
Thanks fellas... I shall search for a used one.... Any ideas.....?
Old 06-07-2011, 10:31 PM
jahummer's Avatar
There are some on ebay right now
OEM 04-08 XJ8 XJR LH MASTER WINDOW SWITCH w/ FOLDING | eBay
USED POWER WINDOW SWITCH JAGUAR XJ8 2006 | eBay
Old 06-07-2011, 10:33 PM
Jsedita74's Avatar
Funny I actually made that guy an offer about 20 minutes ago for the 130$ one... Thanks bro your the man!!!!!!!!!
Old 06-07-2011, 10:46 PM
jahummer's Avatar
There are a few more for around $60 or so too. Make sure you get the right one, if you have power folding mirrors or do not have power folding mirrors...there are 2 different ones.
Old 06-07-2011, 10:49 PM
Jsedita74's Avatar
I have the folding mirror one. That was the only one I could find
Old 06-07-2011, 10:58 PM
jahummer's Avatar
Depends on what it is worth to you, but a new one comes with warranty. Nothing wrong with used, but you should not pay more than $100 used/no warranty.
Old 06-08-2011, 12:32 AM
Jsedita74's Avatar
Made that guy an offer for 75$ and he accepted it . It's worth 75$ to me and said it's guaranteed 100% working
Old 06-08-2011, 02:14 AM
Chuck08XJR's Avatar
Good luck with that.
Old 06-08-2011, 08:58 AM
jahummer's Avatar
Very cool, hope it works out!
Old 06-14-2011, 03:10 PM
Jsedita74's Avatar
Got that window switch today and. Changed it in 10 mins !!! 2 screws and it pops out. Works like a charm... Feel so much better now ! Lolol I'm such a baby I want everything working properly!!!! I know I have 74000 miles on her but I want it working mint!
amcdonal86 (06-14-2011)
Old 06-14-2011, 03:21 PM
amcdonal86's Avatar
Thanks for following up!
I am exactly the same way as you--I want my cars to look and drive like brand new. Unfortunately, maintaining these exacting standards is very very costly, which is the whole reason I try to drive another car most of the time, as you may recall. Doing so also helps me to be less sensitive to this car's gremlins.
To get my car to brand new, I think I will need to have the following done:
1. Replace headliner (some sagging underneath visors)--$600
2. Replace tires (some vibration at highway speeds, probably flatspotting)--$800
3. Repair/repaint wheels--some chips are visible--$150/wheel
4. Replace power steering pump/rack (stumbling in hot temps)--~$3000?
5. Replace shift knob (cracked)--$70
6. Fix minor clunking sound in transmission (perhaps drain/refill tranny)--$200
7. Transmission reflash/TCM clearing--$300
8. Engine ECU reflash to address knocking issue--$150
It all adds up to a crazy sum of money, and this is on TOP of normal maintenance.
I think you have already been experiencing this. A used car that is seemingly already in tip top shape can always be improved. You've replaced all kinds of stuff already, including the window master switches, A/C vent knob, and are still trying to figure out what's going on with a grinding sound at 10mph!
Old 06-14-2011, 05:52 PM
Jsedita74's Avatar
Lmao you are right Alan. Thus far I've changed the master window switch and the 2 subwoofers. Next up is the fog lamps as I ordered a xenon kit 3000k yellow.... Already working on headliner options. I want alacntra for sure... Other then that so far so good...
Quick Reply: Problem w driver side window
