R badge replacement
some trim parts can be installed with a double sided adhesive tape. The tape is applied to the part, for instance the R badge, the excess tape is trimmed off using a razor knife then the R badge can be pressed onto the car for final installation. Best applied in warmer weather to a clean surface. good luck Th tape is available at auto supply stores, Walmart etc
RoyLittle0
05-25-2023 02:38 AM
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
davidladewig
09-03-2015 06:32 PM
