Radiator Cooling Fan Not Activating
2004 XJ8 with 145K Miles
I noticed my Radiator Fan was no longer working lass Fall. Since I live in a northern climate I deferred this job. I recently purchased a used radiator Fan off of EBAY and confirmed it was working. I installed the fan with no issues. When I began to fill the radiator I had a number of air bubbles that needed to be released. As a result, the engine ran hotter and the fan kicked on. After adding coolant a number of times I was able to eliminate any trapped air and the cooling system seems to be working fine. Note, I also replaced my hoses and thermostat housing as well. What I have noticed is that the fan is not coming on. This is with temperatures in the mid-80s. My temperature gauge always seems to stay right in the middle. Again the only time I saw the fan come on was when I had pockets of air and it registered higher than normal. Also I thought when you ran the A/C that would automatically kick on the radiator fans as well. I would appreciate anyone's informed thoughts on this matter. Thank you.
Received 2,632 Likes
Do not use the instrument cluster gauge to monitor coolant temperature. The gauge does not change from 96 C to 129 C, which may be too late to avoid an overheating situation.
Use the Torque app on a smartphone and connect to the PCM via the OBD port with a Bluetooth interface to monitor real-time coolant temperature. The radiator fan speed and cycle is controlled by the PCM.
mmac867
07-13-2019 10:11 AM
M12345678
07-14-2016 12:49 PM
