Radiator/Engine Splash Guard
Underbody plastic cover parts lists
I found this hopefully this will help you out, well you have part number to work with this is from the 04-05 XJ8 parts lists
good luck
cover.docx
In locations where winter salt is an issue, such as the US rust belt and Europe, the main problem is the mild steel zinc-plated fasteners becoming corroded. When the owner or service department has difficulty in removing the undertray, the common solution is to remove it and throw it away. This of course is not the best answer, which is to replace the fittings with stainless steel items and repair the undertray. There are kits of stainless steel fasteners available on the usual online stores.
Where I live, there is no salt on the roads, so I don't have the problem, but I did coat all the nuts and bolts with copper grease to prevent them seizing.
In Ohio, which is, I think part of the rust belt, you really need that cover! You may get lucky and find one at a car dismantling yard, but I think they are also available new from a Jaguar dealer.
Pete M
