Radiator Question
The transmission can be drain by a drain plug at the rear of the pan. However because you may have coolant in it and because odds are yours hasn't been done before you need to replace the pan since it has a built in filter. There is no dipstick for the transmission nor a fill tube. There is a port on the side of the transmission where you pump fluid into it, then pump more while car is on and shifted through each gear for 5 seconds each; all while the car is level and fluid can't exceed 35 or 40 degrees celsius (can't remember which at the top of my head) You can shoot a laser thermometer at the pan or pan bolt heads to measure temperature.
Also, the pan has go be bolted back in a sequence at about 7ft/lbs, careful not to break the pan bolts as I did one.
The process is not as bad as it sounds once you have all the tools handy. Just requires a little patience. There are a few youtube videos on how to fill the ZF 6HP26 tranny which is used in BMWs Rovers among a few others.
Mercon SP can be used as fluid for cheaper. Others and myself have used this fluid.
As the transmission may have forced oil into the radiator. When the engine is hot and turned off the pressure in the cooling system could cause coolant to contaminate the transmission. You could disconnect the transmission lines as described in the link, Use a radiator pressure tester ( Rent at most parts with adaptor kit for Jaguar ) pump no more than 15psi into cooling system and see if any coolant discharges from lines. Confirming radiator is bad and transmission will need to be flushed.
https://www.jaguarforums.com/forum/x...sh-diy-217150/
Good luck
Sorry to here of your Miss fortition
Good luck
This is the link I found
Also I am not sure how the antifreeze/water mix will interact with transmission fluid but if some got in the transmission it would be the worst case.
I would want to know for sure that is why use Radiator pressure tester to confirm if it were a possibility, antifreeze/water mix is not going to play well in the transmission
hopefully one of the Teck's will weigh in on this
If you got transmission fluid in the your radiator you can almost bet you have radiator fluid in your transmission. There are two transmission lines at the radiator one pumps and the other draws. So if it's pumping fluid it's also drawing fluid. Cheaper to drain transmission than risk it. If you haven't drain your transmission before it needs to be done anyway as its overdue for this maintenance. Hopefully not of the coolant made its way into the torque converter since it doesn't drain all the way without removing it.
#28
Another thing I noticed is that the guys/owners are really lucky to have their own garage / parking bays where they can service or DIY repair their vehicles without much relying on the expensive mechanics charges. But here in this corner (UAE) it is not possible to have it that way, unfortunately dependent on the unreliable mechanics. So am trying to accumulate as much info as possible to be able to understand what the mech must do with my vehicle.
Finally, I think that the fluid from the transmision has to be flushed before the radiator is changed, and then refill with the new fluid. Please advice if this is correct. or any correction required in this process.
Thanks to all.
I dont know if I have explained my doubt clearly. Please do let me know.
#30
#31
#32
#33
I am not totally sure however if the transmission cooler is embedded within the radiator and developed a leak within the radiator that would cause the transmission fluid to pressurize the coolant system quite dramatically and cause that mixture out of the coolant reservoir.
That mixture is exactly what a mixture of coolant and transmission fluid looks like.
as has been stated if that is the case then you have coolant and transmission fluid in the transmission.
Unfortunately a really bad problem to have.
Just checked my workshop manual and yes the transmission cooler is embedded in the radiator.
#34
Turns out Jagnew had mixed coolant causing the system to gum up and overheat.
They created a separate thread here: https://www.jaguarforums.com/forum/x...-close-219335/
42Ajd
12-30-2015 09:45 AM
1964Daimler
09-09-2015 11:28 AM
Currently Active Users Viewing This Thread: 16 (0 members and 16 guests)
