Radio is on but no sound
It is likely some sort of interruption in the fibre optic ring. I would re-seat the fibre optic links, probably starting in the trunk area since it is more accessible. Just carefully unplug each connector and plug it back in. I had a similar situation where things weren't working on a really cold day here. Symptoms were radio on but no sound, setup no longer shows the subwoofer available, nav system doesn't work (because it can't see the nav disk), phone module not connected error (for 2008 and above). For me, I got lucky, and restarting the car cured the issue.
Dave
Dave
I would occasionally lose audio but a restart would fix it. I replaced the battery as it was a cheap nasty one the p.o. put on and it died very quickly. No had any trouble since.
I think there is a way you can get the audio equipment to do a check and it will let you know if stuff is communicating ok. I cannot remember how but it was done from the screen.
Radio works now
Radio works now. I went to junkyard and got a fiber optic loop. By passed fiber optic connector into the CDC.
The CDC has no power. There is a 3 wire connector into the CDC. It
is not obvious (to me) how to remove it. Anybody know how
to release it?
Update,short story is 3 of us were working on the car and someone removed the CDC fuse and put it back into an empty slot. All fixed now.
cdc fuse and
to release it?
cdc fuse and
motorcarman (08-21-2020)
tlradcliffe
07-25-2014 08:28 AM
