Radio problems - 2005 XJ8 L
Hello everyone, I'm new to owning a Jaguar as well as posting in forums. Hopefully I can find some answers on here. Here is the problem; When my car is just turned on (ACC) the FM frequencies pick up fine and is clear as day. When my car is cranked all I hear is static and it doesn't pick up any stations. The CD players plays music, and my FM transmitter works fine when the car is on (ACC). That being said I know the speakers are fine and I know the antenna is fine. Honestly I can't even find the antenna on this car to even check it. What else could it be? Any answers or suggestions are much appreciated. I will respond back to anyone as quick as I can. Thank you.
Hey, my radio also has interference when the rear defrost is on, I just did some searching and found a few things:
- check the side panel in the trunk where the antenna is located and inspect wiring.
- another post mentioned that there could previously have been a sirius/xm radio installed and switched the antenna output to that. My car did come with a sirius unit attached to the dash when I got it so I'm going to check now.
misplaced1954
11-21-2019 09:05 PM
