Raindrops on rooftop metal sounds on Cold start
This only happens when the car hasn't been driven overnight and I start the engine in the morning. When I start the engine, a few seconds or minute or two later, I hear this hard to describe sound: it kinda sounds like clicking or raindrops falling on a metal roof. It continues off/on until the engine is semi-warm. I opened the hood and I don't see or hear anything. I just hear it inside the cabin and it disappears after the engine is warm or at normal operating temperature.
philc850 (03-29-2016)
Thanks Meirion1 though I think I kinda know what a noisy hydraulic lifter sounds like. This one sounds like if you take a 12-18 inch long sheet of Reynolds aluminum foil out and wave the sheet, it will make some kind of sound, that's what the sound is what I am hearing, not really a ticking or pinging hydraulic valve lifter.
Received 2,625 Likes
Thank you NBCat. Regarding your first comment, my car is parked in an underground enclosed garage and I never heard that sound before and I've lived there almost a year. At first I thought what you thought that it was just metal expanding but I think it's more than that. Can you please explain what timing chain tensioners lacking sufficient oil pressure involves? I mean is the oil pump going out or the timing chain tensioner is loose or ??? Any feedback would be appreciated. I will record the sound and post it on here if I don't bring it to an Independent Jaguar dealer first.I'm just thinking they mechanic won't hear it unless it stays at his shop overnight.
Very unlikely to be tensioners on this engine, possibly vvt solenoid.
I suggest you search this forum for vvt solenoid noise ( I use
google).
I found this:
https://www.jaguarforums.com/forum/x...sioners-71904/
google).
I found this:
philc850 (03-30-2016)
PrinceRandom
19
08-23-2019 10:13 AM
l3uddha
03-14-2016 02:43 PM
