rattle
Received 2,192 Likes
RE: rattle
THINGS I WOULD ASK YOU TO FIND ARE ..POP OR RATTLE, OVER SPEED BUMPS, INCLINE OF YTOU DRIVE WHEN CAR TWISTED, AND GOING OVER LANE DIVIDER BUMPS. SWAY BAR NOISES ARE EASY, DRIVING SLOWLY IN A PARKING LOT MOVE THE STEERING WHEEL BACK AND FORTH TO ROCK THE CAR, THIS WILL MAKE BAD SWAY BAR BUSHINGS AND END LINKS GO NUTS
RE: rattle
gordo, I can tell you that finding squeeks, rattles, and pops on everything from new to old, no miles to high mileage, you have to drive and duplicate. You'll never find a worn/loose/dry/rubbing component by prying on them under the car without alot of luck. there are way to many things that create noises, and if it where that easy we techs wouldnt use these to isolate noises...and have to spend so much time finding the causes.
http://www.etoolcart.com/ProductImag.../STE6600_L.jpg
best product to diagnose any noise next to experience, you can probobly find even cheaper on Ebay. And how would you find a not fully tight rivits on the left side crush tubes for the front bumpers on 06 XJ8 that you cant even see without taking apart, or finding the convertible engine bay braces are loose on you model, or cool box pops, Xtype parking brake cable squeek, should I go on? I can tell you a half dozen common noises on every model, and many that arent
RE: rattle
ORIGINAL: BRUTAL
RE: rattle
ORIGINAL: GordoCatCar
BRUTAL: I agree with you in principal that it is necessary to drive and roadtest;however,in this particular case, the OP has already indentified possible sources by doing just that.From his road test descriptions, it is likelythe noises are coming from worn control arm or sway bar bushings. These are sometimeseasily diagnosed using a pry bar technique to positively identifydefective parts.My suggestion was to comfirm whether or notthese parts are causing the problem. If not, then go back to the traditional troubleshooting techniques, some of which you outlined above. gordo
ORIGINAL: BRUTAL
MY BAD, ILL TRY NOT TO INTERJECT MYSELF INTO THE MIDDLE NEXT TIME.....
RE: rattle
Hey Gordo,
Hope your Florida sun is running rich. I have a small favor to ask..
There is a thread running started by JimC64, "Must be over surely". Amidst the post-electionhyperbole is a layman'sperspective on our economy that I wrote. I'd be interested to read your critique, as I believe your experience could give me a little more insight.If you have a moment, please peruse and purvey your pronouncements privately. Peace.
RE: rattle
[/quote] MY BAD, ILL TRY NOT TO INTERJECT MYSELF INTO THE MIDDLE NEXT TIME.....
[/quote]
Brutal don't be ridiculous... Jag Techs, like yourself, who participate inforums like this, are the source fora consistently high level of accurate and valid information.Without thebona fide technical expertise andpractical experience you bring to the table, solutions to readers problemscan, and will, end up beingbased on urbanauto myths,half-baked solutions, and sometimesoutright dangerous backyard workarounds. Don't for a moment think we don't appreciate your input. Gordo
[/quote]
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
