Rattle from shock?
Rattle from shock?
I'm losing faith in my car. Seems I can't keep up with the continuous issues. Today I noticed a very loud rattling. I just replaced the steering rack and tie rod ends, got an alignment and all was good. But today, I drove about 200 miles and noticed something new. Any little bump gave a loud rattle. I did briefly look things over when I got home but noticed nothing obvious. But when I push down on the front of the car I get a distinctive noise from what I think is the drivers side front shock. It is a year old rebuilt shock. Is there anything in there that could make such a noise?
I cannot speak from personal experience fortunately, but from reading this and the UK
forum there have been a few cases where a strut has been rattling.
In one or two of these cases owners have had to spend a lot of effort to find the source however
you appear to have identified the problem straight away.
Another source of front end rattling is the ARB (sway bar) bushes. This can be quite common
so you need to be sure before proceeding.
Search this forum for actual posts.
Received 13,425 Likes
Hi Drb007,
I hope they apologized profusely and gave you a HUGE discount, as in a FULL refund, because if one of those nuts had come off while you were traveling down the highway, you might not have been able to give us this update on the source of the knock because you would not have Internet access in Heaven!
I agree with trosty - GOOD THING you caught it!
Cheers,
Don
AD2014 (05-23-2014)
You should take it back to them. They need to redo the alignment because the adjustment has changed. The lock nut is there to hold the adjustment, with it loose I have no doubt that the alignment is no longer perfect. They need to check it at least for free. You'll pay for it in tire wear if you don't.
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
