Re left hand side rear door lock actuator
Just picked up the kids on Friday and had to manually unlock the back door have noticed this before but not many people sit in the back noticed it again this evening when I took the kids home
Had to replace the left hand front one a couple months ago had a heart attack when I payed for it so this time anyone know what the part number is also is it true I can use one from a mondeo
The door locks from a Mondeo are very simliar except they do not have the
shut/open sensor for the alarm system also the Mondeo actuator connector
is 3 pin and the XJ is 4 pin, although th XJ only needs 3 pins and the 4th. is
not used.
Im am sure that you could frig a Mondeo lock to work on an XJ.
Easiest repair is to buy an used Jag lock from E bay Uk however if you are
really clever (and tight) (like wot I am!!*) you can cut the microswitch out of
an used Mondeo lock and solder it into your Jag lock.
BTW Do not use double locking.
not used.
not used.
not used.
Seems they are a problem there are a lot of guys selling just the cogs as well
I ordered a new latch but as soon as I have the old one spare I am going to see if it can be repaired with this or another type of kit as there are a few different ones for sale on eBay Australia
I have the old front door latch actuator as well might be able to repair them and have them as spares or at least learn how to repair them
Have a look in the S-Type section for the thread "S-Type door lock actuator repair FAQ" it was posted by joycesjag & I posted in there as well. You can see what I had to do to get the door open.
msdg137
09-16-2015 06:24 AM
SingBlueSilver
08-27-2015 02:20 PM
