Re-programming ECU
chris2806126 (03-21-2015)
with my mangoose clone, flash times seem to be 3 times the normal time.
After 40min flashing the tcm, I started to become real nervous... as I read other users to have flashed tcm within 15minutes.
As long you obd2-lights are blinking and the clock in SDD runs, the process seems alive.
For the health of their users, SDD programmers should add a progress bar when flashing..
Starts and runs great. Working on DDM now.
Thanks for all the help about waiting.
That's why it's better to use VCM or Mongoose Pro. Progress bar works fine with them and it takes a few minutes to flash.
BTW, yesterday i've bricked a ECM on STR, while i was trying to flash it with Mongoose. Rectification procedure didn't work, after i connected a VCM everything went fine
It's a pretty common situation.
I was able to reprogram the FEM and the DDM and they are working fine. Only thing I have now is a message saying 'CONFIG F' and the yellow and red lights continuously flash. What does CONFIG F mean, which module needs programming....
chris2806126 (03-22-2015)
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
Thanks.....
Hello!
Need a little advice. I was flasing existing PCM and i took 1H 5 MIN and no screen change but clock was ticking. Progress bar did not show anything. As i understand it can take up to 2 h with mongoose? Now car wont start. Some time ago when i was flashing other modules like rem progress bar was working
joesoap
09-10-2015 01:09 PM
