rear air strut
Old 06-28-2017 | 01:24 PM
romroc's Avatar
Default rear air strut
No sooner do i replace susp pump get all lights off than right rear strut wont inflate at all. Question what type of bolt holds the lower bush? Is it a torx? A 60 i take it?
Thank You, gonna enjoy this.
Old 06-28-2017 | 01:45 PM
romroc's Avatar
How does the trunk side carpet come out to access top of strut?
Old 06-28-2017 | 02:27 PM
romroc's Avatar
Got carpet out, accessing top of strut. Loosened air fitting, some air escaped, which i didn't expect, as right rear is visibly low and wont raise. Whats up with this?
Old 06-28-2017 | 02:44 PM
romroc's Avatar
Fired engine, STRONG air supply to right rear strut, why is it holding some air but not rising? A federal investigation is in the works.
Old 06-28-2017 | 05:09 PM
Partick the Cat's Avatar
There is valve in the top of the strut that is designed to prevent it depressurising below about 30 (?) psi. It's to prevent the bladder collapsing when the air line to the strut is disconnected.
Old 06-29-2017 | 07:46 AM
kritchai's Avatar
Unhappy Rear Air suspension is in highest position.
Dear Guys,
I have Jaguar XJ8 4.2 litre MY 2004 , I have problem with rear suspensions when i park this car overnight it was rised up to highest position. this is happen after i replaced both rear air suspension strut. I tried to release air pressure in system but the struts are not lower. These look like struts do not release internal pressure.
Can any guys have suggestion to solve this problem
Thank you in advance for your suggestion.
Kritchai
Old 06-29-2017 | 08:59 AM
romroc's Avatar
Originally Posted by kritchai
Dear Guys,
Kritchai
Try to get a Jag specific scanner and read under air suspension. My guess (guess) is that valve block is needing a cleaning/swap. I bought icarsoft LRII. A 930 might do as well.
Old 06-29-2017 | 09:24 AM
kritchai's Avatar
Thanks you very much.
Kritchai
Old 07-01-2017 | 11:18 AM
romroc's Avatar
Good luck getting a scanner to read. Mine says 15 on all four, when right rear is known to be leaking.
Old 07-07-2017 | 10:12 AM
romroc's Avatar
Shipment today RMT rear strut. Emailed them and satisfied with their response. Included: return label, prepaid. Does dealer offer this service?
Old 07-07-2017 | 06:53 PM
meirion1's Avatar
"Thank You, gonna enjoy this."
You won't if you can't get it out-some have thread lock on the bolt. lol
