Rear CATS connections
Received 12,946 Likes
Vinny,
The tops of the air springs/shocks are farther forward than you think, almost to the trunk bulkhead behind the rear passenger seat. You'll see four nuts that secure the air spring assembly to the body and an electrical connector in the center.
Regarding your CATS fault, do you have the capability to scan the Chassis (C) fault codes that can trigger the CATS warning? That would help narrow things down more quickly.
Cheers,
Don
Cheers,
Don
Vinny,
Cheers,
Don
Cheers,
Don
The one time I encountered a CATS Fault was right after I installed new front springs. Arnott uses a coil (inductor) to emulate the original shock valve so the system thinks everything is okay. Long story short, the coil they use has insufficient insulation and broke down from coil to ground. This set the CATS Fault error. Insulating the coil with some tape solved the issue.
Don B (05-11-2016)
Agree with Don, the OE CATS system is fairly rugged. What has you looking at the rear shocks?
Vinny,
Cheers,
Don
Cheers,
Don
I do not have a scanner for checking the chassis codes. Is this a different scanner than the one I use from an auto parts store?
Don B (05-11-2016)
First remove the connector and check resistance from each pin to chassis ground. Should have infinite resistance (no connection to ground). If it does have low resistance to ground, you have coil insulation breakdown as I did. Take the cone off, pull the coil out, wrap with 1 layer of electrical tape and reinstall.
The following 2 users liked this post by mhamilton:
Don B (05-11-2016),
grantorino62 (05-12-2016)
Cheers,
Don
VinnyT (05-12-2016)
The generic OBDII scanners that the auto parts stores use can read most of the P or Powertrain codes on an X350 (by law), but to read the proprietary C (Chassis), B (Body), or U (Undefined, mostly network-related) codes requires either a Jaguar dealer-level system such as SDD or a high-end third-party system like AutoEnginuity with the additional Jaguar enhanced interface. It might be worth checking to see if there's a good independent shop in your area that is equipped to read late-model Jaguar codes. Some members of this forum also have versions of SDD or the earlier IDS/WDS systems running on laptop computers, so it might be worth asking if any are close enough to you to scan your system.
Cheers,
Don
Cheers,
Don
Thanks Don.
I will try to find an indy around me. There is a Jaguar dealership near me, but the service manager is a little butthole kid with a bowtie.
klintous
04-15-2022 10:44 PM
