Rear control arm bushing replacement
Old 04-03-2014, 06:26 PM
Terry H's Avatar
Red face Rear control arm bushing replacement
I have a 1996 XJ6 and I need to replace the rear inner control arm bushings. Do I have to drop the complete diff to remove the long through bolt? Is there another way to change the bushings? Is this something that an average mechanic can do with normal shop equipment or is there specialized equipment needed? If I mark the location of everything, will I still have to get the rear end re-aligned? How long should this job take per flat rate (so I will know if I'm getting screwed if I end up using a local mechanic do the job)?
Old 04-04-2014, 06:24 AM
Partick the Cat's Avatar
Hi Terry
Ah, you need to post in the XJ ( X305 ) XJ12 forum; this one is for X350s which ran 2003-09.
Dave in Gloucestershire GB
philwarner
12-06-2021 07:13 AM
Fraser Mitchell
10-01-2015 04:06 AM
frujag
09-01-2015 03:43 PM
Doug Dooren
08-30-2015 08:51 AM
perfectphoto
08-29-2015 10:11 PM
Quick Reply: Rear control arm bushing replacement
