Rear courtesy light Issue
Had a new headliner put in my 2006 XJ8 ($500 with all pillars and sunroof) and now the rear courtesy lights stay on for a very long time. Hours it seems. I thought they just were not going off at all but went out a couple hours after parking to remove the bulbs and they were off. As soon as I opened the door they came on again. Is there a way to adjust the timing on these?
Thanks for any help,
Frank
Frank
Frank Hires (12-28-2015)
Connection in upper console
If I remember correctly, the upper console has 'pins' which connect into a 'receiver' on the car side. I am wondering if these are connecting properly; perhaps a pin was bent while the upper console was put back into place after the headliner work.
You may want to pull the overhead console down and inspect the connectors for the map and courtesy light.
Thanks-
mag
Thanks-
mag
Frank
Frank
Unscrew the rear handles, unplug the harness and swap them. Seems like they have them backwards when putting them back in your vehicle.
That should solve your issue
I think Evan may have it.
The courtesy light and the map light have a common 12v suppy and are switched in the earth line; the map light has a switch (in the fitting) and the earth line then goes directly to an earth point, whereas the courtesy lamps's earth line goes to the rear electronic module where it is switched to earth. The two earth lines maybe swapped over.
Acid test:
i) switch on the map light, then with all doors closed ...
ii) switch off the courtesy lights using the central button in the front map/courtesy light fitting.
If the rear map lamp goes out then it's earthed (wrongly) to the REM, and the courtesy is connected directly to earth which is why it stays on.
Hope that makes sense.
Edit: Yes, looking again at the wiring diagram it seems as if the common supply is on the middle pin (pin 2) of the connector and the earth returns for the lamps are on pins 1 and 3, so if the connector can be fitted the wrong way round ...
I'd bet money that Evan's put his finger on it.
Acid test:
Thanks-
mag
Thanks-
mag
I see that now...
Apologies.
-mag
The following 2 users liked this post by hafren:
Frank Hires (12-28-2015),
Partick the Cat (12-15-2015)
Hello: I just got this car and rear courtesy lights do not come on ever at all. If the front lens is pushed, the front bulb lights (sometimes) but rearward bulb never gets power. I switched them; both bulbs are good. I have spent couple hours trying to find wiring for this circuit on 04 xj8 in vain. Would the person who described the earth path through the control modules please reply with specific attachment to that diagram? Thank you. --Tom in AZ
Hi: After looking at the electrical guide (thank you) I found a blown 5 amp fuse in the rear terminal box for the courtesy and rear footwell lights. The diagram calls for a 10 and that is what I put in there. My ammeter showed initial draw of over 5 amps just for a bit but that was enough to blow the smaller fuse. All is good with the 10A fuse. Wondering why a 5 was in there when diagram calls fro 10? Anyone else had this trouble? --Tom in Tucson
OK, first of all sorry it took so long to get back to this but the holidays are a hard time to get spare minutes. What I did was pull a rear courtesy light down and the two wire plugs were different size so they couldn't have been swapped. Evan had it right as they had the left light set on the right and visa versa. Thanks Evan. Patrick was right with a good clue as the map light is the front light and if they are switched it'll be the back light. Thanks everyone for the help.
Happy Holidays
cartopics
19
11-26-2015 11:35 AM
200Volts
11-23-2015 07:29 AM
pauljag
11-20-2015 09:38 AM
