Rear differential leaking
Old 12-22-2021 | 07:03 PM
SJ9809's Avatar
Default Rear differential leaking
Hi,
On my 2006 XJ8l the rear differential is leaking, it’s not enough to drop the the floor but I have to address it sooner or later.
From what I see it’s only on passenger side, so I guess it is just the axles seal. How difficult is the work. Drop the axle or is it possible to just pull out the CV axles and replace the seal.
Any advise is highly appreciated!?
what fluid should I use for refill and how much?
Old 12-23-2021 | 12:32 AM
xalty's Avatar
yes you can even detach the CVs with the knuckle some put up a fight some will just pull out.
seal is XR821244/National 71085
use motorcraft 75w140 or equivalent
Captain Bob 369
10-06-2021 03:09 AM
sambella
10-01-2014 04:02 PM
David N. Warner
03-30-2014 02:00 PM
magicjuan17
05-31-2013 11:33 AM
DaveC
01-09-2013 04:17 PM
Quick Reply: Rear differential leaking
