Rear door won’t lock.
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
This is a weird problem. One of my rear doors won’t lock with the remote – I need to put in my hand to push the manual lock/unlock actuator and then it requires some force. When that is done my remote will lock and unlock the door normally until I open the door again, and again I need to lock it manually from the inside to make it lock. All electrical parts are working but somehow opening the door does something that creates too much friction so the electromagnetic actuator is not strong enough. Any Idea’s? – the door operates perfectly otherwise – I am thinking the lock plate in the door frame might need to get adjusted – I need to buy the special star key tool to adjust to test that one out. All has been lubricated.
Martin
Martin
99xk8guy
06-05-2023 06:28 AM
