Rear entertainment
Welcome to the forum Coryc10,
I've moved your question from General Tech Help to X350 forum. Members here with the same model will be able to help.
Press power button in screen
Turn on rear seat control by pressing down round volume button
Press right button (the one with the audio labeled button and the one marked 'left' to its left- those 3 are between the two volume knobs.
Press audio select until dvd shows
If not working try the numeric key marked play
Make sure rear ent in enabled / allowed from front touch screen
Also if you have trouble controlling system from front afterwards, try switching audio input to radio that freed it up for me
I had to fiddle around for a while but eventually got both screens and audio going
This sounds similar to what I have tried. I will mess with it again tonight. I havent tried changing any settings on the front screen. I need to get this figured out. My 2 year old daughter is giving me hell because she sees a tv but she cant watch it lol Ill let you know if I figure it out. Thanks.
Not sure if that is the problem for you because when this is off rear control small led screen says system locked or something like that
Good luck! I had same challenges and managed to get both screens going somehow although in the end not sure what buttons I pressed in what order
You did put a movie in the trunk mounted DVD player?
alecescolme
05-14-2016 09:23 PM
kingcobra
04-19-2016 02:22 AM
jag_genius
04-04-2008 02:45 PM
neillebo
12-21-2007 07:02 PM
