Rear Rattle
I took it to my mechanic. He looked over the car for several days. He opened up the trunk, removed the trunk covers, and told me to hold on to the shock stem while he pushed down on the car. You could feel the noise just holding on to the shock stem in the rear. We are now replacing the shock on the right side to see if this the problem. These are strut masters and this should not happen. Called strut masters and of course they have never heard of this happening. Sounds like a standard government answer. If you hold on to the left rear shock stem, you can feel some noise thru it too.
When I purchased the car, the shock conversion had already been done with StrutMasters. When I replaced them this time, StrutMasters were bad. What I don't understand is the car has only 70K miles.
It would be a great dollar amount to revert back to the air ride. I would have to replace everything in the air shock system. I just accepted that the air shock system is history.
WaterDragon
07-02-2021 06:01 PM
