Rear side marker lens removal
I use a small flat head screw driver, i carefully at the top of the light, where the front where it meets the chrome trim, pretty the light off. There its a metal tab there that locks it into place. Carefully depress it down whole pulling out the light from the trim side of it. Thus should work, with finesse and manipulation. Let me know if this helps. In the car of my jag, the housing are cracked where the light bulb inserts. This makes it kinda difficult. The light bends a bit to much while removing, causing the red cover to separate. Careful!
Road_King (09-16-2012)
davidladewig
09-03-2015 06:32 PM
innzane
09-02-2015 10:08 AM
