Rear speakers not working
Obviously start with the speakers themselves.
FIRST.....MAKE SURE THAT SOMEONE HAS FOOLED WITH THE FRONT TO REAR BALANCE CONTROLS.
I doubt it's them but I'd temp. hook a known good speaker back there just to double check. Next would be wiring which can be checked with a multi-meter signaling continuity. Last, and most likely, is the rear channel output side of the head unit itself.
Any scratching or static like sounds coming from the rear speakers as you adjust the balance or volume? That's an older indicator of trouble pretty much confined to the mechanical portion of the controls and indicated an internal short caused by accumulated crap of the mechanisms themselves.
You'll most likely have little to no luck finding a repair facility as we are now a replacement society. They appear regularly on eBay for between $100-150 from the salvage lots who guarantee them for fit and working condition for a short while in most cases. If you go that route make damn sure it's for a later model XJ8 with the fiber-optic connections.
A few examples:
04 07 Jaguar XJ8 Factory CD Radio 2W9318B876BK | eBay
Both pieces:
04 07 Jaguar XJ8 CD Radio Player LKQ | eBay
A few examples:
Both pieces:
pearlfisher (05-04-2013)
As they were both out when I bought the car second hand, I will have a look to see if it is the speaker connections, as I have no idea when they went out.
I don't really notice it much, and the last owner was on the phone a lot and hadn't bothered fixing the trunk(boot) cd changer when the cassette locked up.
BrentGardner
28
04-26-2024 03:08 AM
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
Fraser Mitchell
10-01-2015 04:06 AM
