Rear strut - longevity
I am considering a cross country trip in my 2004 XJ8. I have already replaced the front struts after one of them blew out. Any suggestions as to if I should replace the rears as a preventative maintenance issue? Most of the comments on this forum relate to replacing front struts - is rear strut failure a rarity?
Thanks for the input
Dan R (08-30-2018)
My wife is Italian from Rome, and we have driven there twice in 2007 in a Rover 75. Just had holiday near Nuremberg in Germany and did just under 3000 miles. I wouldn't worry about the struts. There are plenty of struts on the net new and used if you want to take one with you as a spare, "just in case".
I can only speak to my personal experience. I have had 2 X350's rear struts fail at about 150,000. On my 2004 (with which I was forced to part company at the point of a gun) the first rear failure was catastrophic at about 145,000 miles. Perhaps that story should go under the thread Do You Still Get Compliments On Your XJ8. The other 3 failures were the usual leaks. None survived past 155,000.
Dan R (08-31-2018)
I would imagine that enabling such an action would create a lot of business for (for example) Arnott, but what do I know?
Some interesting commentary here. I didn't realize the X351 only had air shocks at the back. My car has only done 70K miles and my suspicion is that the front struts suffered dry rot in the florida heat. If that is the case, then the rear shocks should be just as "at risk". My gut says to replace the rear struts anyway using RMT rebuilds at a cost of $500 or so. Having already successfully serviced the transmission and replaced the front shocks, I will have reduced the chances of a catastrophic breakdown significantly.
I admit to not quite getting the idea of swapping out the air struts with coil springs, particularly when even new luxury cars are charging extra for this technology. It isn't even significantly less expensive over rebuilt air struts. If I can get 10 years out of the rebuilts I figure I am well ahead
Steve
Steve
