I'm in the process of de-rusting and coating as much of the rear subframe as I can get to without removing it. I’d like to remove the rear cross brace for cleaning and painting, I have the rear of the car on ramps, all the bolts have loosened but is it safe to remove the brace as it is?
Also, the two large bolts - that go through the rubber subframe mounts, do they have nuts at the other end or are they screwed into the car body? I had a look through the service sheets but can’t find any detail on this.
Mark One
Mark One is offline
Junior Member Thread Starter
Default Rear Subframe Captive NutsHi
Recently tried to replace a rusted through NVH brace which is secured by the front rear subframe bolts ,when trying to undo the bolts the captive nuts started spinning inside the chassis mounts .
the bolts and captive nuts are rusted solid and it is virtually impossible to get access inside the mounts , the subframe bolts are now loose , any info on how to overcome gratefully received .
I managed to remove the bolts from the front subframe mounts. I don’t think it would have been possible without the induction heater. Thankfully, when I originally attempted to remove them I paused thankfully not damaging the nut ‘clip’ too much.
The heater got the exposed part of the bolt cherry red, after that it was a doddle.
