Rear Subframe Differential "isolator" Bushings
Hello,
I am trying to find a solution to something I've not encountered before. The "isolator" bushing for the differential on my rear subframe has deteriorated and I cannot seem to find a replacement.
On the above photo #5 would be what is needed, but this diagram is not from a x350/x358, but is from an XE and I have no idea if the busing is compatible, but I would be highly doubtful. Jaguar says the bushing is not available for a x350 outside of purchasing an entire rear subframe, and the subframe isn't available anymore either.
As a attempt I contacted Ford and checked on a Lincoln LS and a Thunderbird to see if there might be something there for the "similar architecture." The Thunderbird had a listing for the bushing as an "isolator" but it was no longer available either. I presume the only way forward is to get a used part or to find someone to make a poly bushing insert?
Has anyone else encountered this problem and if you did came up with a solution?
Thanks for your time!
Any idea what that might be? I'm pretty sure I checked the S-type catalog as well, but I could be wrong. I was exploring Ford as sometimes they have a bit more forgiving catalog.
The following 3 users liked this post by Six Rotors:
Higgins
09-13-2020 03:33 PM
JaguarJoey
03-22-2018 09:24 AM
