Rear sway bar bushings in an 04 XJR
Has anyone done rear sway bar bushings for an 04 XJR? I am refreshing my rear suspension this spring and the initial inspection makes it seem like the air strut has to come out to get to the bolt for the cage, but I am unsure. I haven't started taking things off yet but wanted to see if anyone had done the job and knew the answer. Seems like I can do everything else in the rear without removing the strut so I want to avoid it if needed.
al_roethlisberger
07-09-2017 11:00 AM
XJ8JR
10-21-2015 12:04 PM
