RECOMENDED: Fuel pump replacement for 2004 VDP XJ8?
Of all the different types of replacement fuel pumps for the 2004 VDP XJ8 which one is the most popular, works well, value for money etc..?
I have spent all day on the internet and I am totally confused!!
The " Delphi" FG1712 looks good at RockAuto for $398, but who knows...Recommendations PLEASE
Also while we have the tank open do we need to replace the LHS Sender unit?? My Jag mechanic thinks its a good idea, but its another $350??
djpxk8 (06-16-2023)
I believe my Jag Mechanic is going to drain all the gas out the tank and then pull it out enough to fit the fuel pump. He suggested while the tank was out enough to replace the LHS at the same time?
The car is a 2004, nearly 20 yrs old and the mileage is 80K
Many thanks for your information!
OK, just to confirm, I can remove the rear seat in my 2004, xj8 vdp and just remove the fuel pump and the LHS sender by just lifting them out, obviously after removing the metal clamps? There is no need to cut out any holes as I have seen in some notes for the XK series?
Does anyone have any photos of the top of the tank with the seat removed?
Thank you all so much for your insight and information, it is very much appreciated!
djpxk8
06-17-2023 11:50 AM
