Recommended brake parts for 2004 jaguar xjr
Hi. i hope i post this in the right thread.
i have to change my brakes but im not sure what parts to buy and the best place to buy it at.
my mechanic said i have to change the front breaks and routers.
and the rear routers only.
can anyone tell me what the parts i need looks like (with pictures) so i know that i buy the right parts.
thanks in advance
thanks in advance
We British call "routers" differently as "discs"
Anyway, as a 2004 XJR, I suspect it will have the Brembo brakes and discs. These tend to cost more than the standard discs, as do the pads. With a car of that performance, I would not be trying to save money on brakes !! However there will no doubt be after-market discs and pads, but not calipers, but you don't need those anyway.
I went with R1 rotors for both my 04' XJR and the wife's S type. They have been a great Brake rotor in performance and looks. I went with EBC red for the pads. I was told before purchase to go with drilled rotors not slotted or a combo slotted/drilled as I will get better performance that way. I don't know if there's truth to it, but I know that's what I did and they work great. I live in South Florida with high heat and long straight roads were I am running at higher speeds than most. They have held up quite well. I changed out the front two with a floor jack in 40 minutes total...not a hard job at all. Here is the website link R1 Concepts Car Brake Rotor Disc - OEM Rotors, Slotted Rotors, Cross Drilled Rotor, Cross Drilled and Slotted Rotors, Brake Pads, & Brake Kits . I went drilled premium.
