Refurbished Sepangs? Photos colors?
Hey all,
So for some reason my Sepangs have started to loose their finish over the past few months. It has ben a slow process which has speeded up quite significantly. I also see a few bubbles near the center caps. This is for my platinum 2004 XKR. I do like the factor look however I am unsure I will get a powder that matches. Any ideas? Photos?
Thanks!
Thanks!
as long as you get them all repainted at the same time, they will match. It is less important that they match the wheels on some other car.
that said, when had my wheels refinished, the shop seemed to know the paint colour required.
If you have yours done, get the inboard part of the wheel painted as well. It is much easier to clean when in is smooth and shiny than if it is bare metal. it will need polishing or blasting. All this is easier if the tyres are off and the valve is out.
You will get a better result if you have the disk taken off the drum, and either throw away the stainless ring, or buy new ones. They somewhat expensive. You will need a competent and experienced wheel finisher to dismantle the wheels and re-assemble with a new seal, preferably painting the parts when dismantled and no screws in the way.
Before you spend money on paint, have them tested for truth and if necessary bent back to shape. They tend to buckle on the inboard edge due to the very low profile tyres, and absence of support from disk or spokes. If they are cracked, you can probably buy replacement wheels cheaper than a good quality repair. I keep a repainted spare with tyre in case I have to take one in for repair. It will not fit in the boot unless you remove the protective foam over the air bottle.
XxSlowpokexX (11-30-2014)
Got Sepangs on my XJR and had all five refurbished last year, although mine are the ones without the stainless trims (thank God!)
The people who did the refurb painted them "BBS Silver" apparently. I seem to recall Sean B mentioning that the colour of the BBS wheels was "Mercedes Sparkle Silver" but when I touched up one of the BBS Monaco wheels on my S-Type I got a can of Merc Sparkle Silver made up, it didn't really match...
If you get all your wheels done at the same time then they will match up, but if you ever have to replace one it might not match...
XxSlowpokexX
I have the same color and year XJR with Sepangs as well. Black interior on mine. A few years back, I replaced the trim rings and repaired a few dings in the spoked portion when the wheels were disassembled. I actually took the spoked portion to a local auto supply store and purchased a few bottles of brush touch up paint to get the best match.
If I were to replace the trim rings again, I would probably get at least the spoked portion of the wheel repainted. And yes, I do agree, painting the interior part of the wheel would keep it cleaner. I clean the inside of any mag wheel when they are off the car, for any repair etc.
RyeJag
RyeJag
The spoked portion is where the finish is fading. Its definitely getting redone. I was just thinking powdercoat instead of paint for long term durability. Do you know what the color of the touch up paint was? I will have to think about the doing the centers. I don't drive the car much so it really doesn't get dirty and removing the tires to do the centers makes me think ehhhhhh. Im currently dealing with a motor mount issue so this is next on the list. No rush as winter is here
Many thanks@
Many thanks@
hunter34
19
09-14-2022 11:09 PM
trosty
01-08-2016 06:43 PM
MC36
US Lower Atlantic
09-24-2015 09:49 PM
Ipc838
09-13-2015 03:27 PM
