Removal of Door Threshold Plates
I needed to change the Driver's door Aperture Seal. I had about a six inch section that was torn and causing wind noise.
To get the bottom section loose, I had to remove the door threshold plate.
It took me a while to figure out how the plate attaches.
Here are photos of the threshold with the plate removed and the molded in clips on the underside of the plate itself.
Panthro (05-28-2020)
