Removing Cabin Filter Case
The cabin filter housing is disconnected from the plastic grommets and the insulation on the outside of it has been easily removed. The bottom of the case is slid under the scoop up against which the cabin filter fits. The cabin filter has also been removed.
The Case will not come out from under the scoop. Any ideas?
Thanks, Steve
Thanks, Steve
The case is fixed with nuts (10mm, if I remember correctly) that need to be unscrewed. First you remove the cabin filter and then you can look for the nuts to be unscrewed. I assume that you have already removed the cowl vent screen, otherwise you will not be able to reach all of them.
I have found these pictures from when I did the valley hose, you can see some details of the cabin filter housing if you zoom in. Unfortunately, I do not have better ones.
Best regards,
Thomas
Best regards,
Thomas
Thanks, Thomas; eventhough, your pictures are not exactly inspiritional
Yes, all visible fasteners in and around the case have been removed & the cowling, etc. too. The insulation came off quite easily. Bottom of case is slid under the intake, over which the filter, etc. fits. Will revisit later in the day & see if I've overlooked anything.
Best,
steve
Best,
steve
04Xjrsteve (03-24-2024)
2018XF25T
F-Pace (X761) / C-X17
06-12-2022 08:03 AM
