Removing intake manifold to change one little coolant hose?
Gordon,
My wife drives an 06 XJ8 (90K miles), and I just replaced the thermostat housing last weekend to cure a coolant leak. . .well, the leak actually appears to be from the very hose you mention above. I imagine the throttle body comes off again, and then the intake manifold (and both frame rails?) The hose is only about $10, but labor (if I wasn't doing this myself) would be well over $500 I imagine. Any photos or further advice?
Cheers,
Chris
Cheers,
Chris
My leak isn't drops of fluid, it is coming out (under the car, between the engine and transmission) at a steady clip. I do not have the replacement hose yet, but will pull what I can and post pictures. Since I just had the throttle body off (and then back on) last weekend, that shouldn't take long! My only concern is getting the intake manifold off. I hope that goes smoothly. My intent is to undo the four nuts holding the two frame rails, then remove the intake manifold bolts and see if it will all come up enough to reach the hose fitting.
I have access to the other end of the hose now (at least I think I do. . .I'm going to wait until I have the new one in my hand to remove the other end).
I removed the throttle body, the thermostat housing (both parts, which I had just replaced last weekend), the metal portion of the intake manifold, and then disconnected the wiring harnesses running along either bank of cylinders. I then removed the bolts holding the intake manifold in place. I was then able to raise the intake manifold/fuel injector assembly high enough to get my hand in and feel the hose. It appears to run aft initially, then it makes a U turn and attaches to the rear of the base onto which the smaller portion of the thermostat housing bolts. If I could figure out how to post pictures I would (or someone might tell me how ). More once the replacement hose arrives.
Is the intake gasket metal? I'm wondering if once it's popped if it needs to be replaced. I'm guessing the hose from the throttle body has one of those clamps that you put on with the special pliers like the other hoses. I noticed some of the new hoses I bought have those clamps you can squeeze with regular pliers on them; some of the others I put the old screw kind on.
The hose is held on with the small clamps you have to squeeze (I hate those things although these were small enough a pair of pliers are okay).
#28
Can't understand why it is plastic on the NA, but metal on the XJR.
StellaLunaGardens (09-20-2016)
#31
#32
StellaLunaGardens (09-21-2016)
#33
It is a good idea to replace the thermostat housing each time the coolant is changed as the plastic housing can only stand a finite number of cold and hot cycles.
The housing assembly includes the thermostat and seal. There is no aluminium replacement for the 4.2 litre NA thermostat housing.
The following 2 users liked this post by NBCat:
abonano (09-21-2016),
#34
lol ,I just don't even get surprised any more when small things happen to this beautiful car that cost me dearly if I don't fix it myself.This sounds like my problem at this very moment,I was on track to change thermostat,then notices housing needed to changed.Now i think about it ,the car was leaking from above,then running down the transmission .I'm convenced its that $10 hose also,I haven't went under manifold yet,I think I'll call mechanic for this bad boy lol.Mind as well change that hose.I love this car ...........
#36
#38
RE: Fuel Line Connector: ...Fuel line connector for xj8 X308 series is a ford style quick-release tool, available at any autoparts store, such as Autozone. Same connector used on all Fords of this era.
Important to know how to do, because this critical knowledge to have, if you ever have to replace your fuel pump (which is inside the gas tank). If need be you can create one of a piece of metal tubing.
