Removing the vent cowl to screen panel and Top wishbone
About to start overhauling the front suspension of my XJR 350 2004.
At this point I do not intend to remove the top wishbones as they are in good order.
But I assume it will be necessary to gain access to the inner fixings i.e. the nuts on the bolts of the inner bushes of the top wishbone when it comes to having the suspension setup again.
I can't see any reason why you can't access the offside wishbone nuts, the front being easily accessible and the rear through the removable cover to the brake fluid reservoir.
But the nearside appears to be more difficult the front wishbone nut again is accessible, but it appears you need to remove the vent cowling to screen panel together with the wipers and possibly the air intake box for the cabin air filter to get at it.
In trying a practice run all went well up until the point where the manual says to Pull the cowl from the screen.
Now I have pulled from one end as directed but it really does not want to move, I am concerned about damaging it and replacing it, so any advice would be appreciated.
If this is the only way to access the rear nearside top wishbone nut I am minded to cut an aperture in the front of the cabin are intake box for easier access by garage, then to cover it with a grommet or plastic pitch. But this would be easier with the cabin air intake box off
Regards Bill Dag
Regards Bill Dag
Thanks for the reply.
That's nice to know my concern is getting at the nearside rear nut, that is left side sitting in the car. The only way I can see it getting at it is to remove the vent screen cow and the cabin filter air box. As I said in my post I am concerned about pulling it off the screen. I have given it a good hard pull at one end, but it does not want to move. Never having removed one before I'm not sure what forces needed to remove it or how it is fixed.
Do you have any experience removing this Cowling and how it attaches at the screen I'd be grateful for your advice.
As always thanks for any advice.
Bill Dag
Bill Dag
Thanks to you all your advice I think I have the definitive answer from a Jaguar enthusiast club member IRS, so I've reprinted it below for further information.
"I had problems removing this item, but you just need to be brave. It takes a good tug away from the screen at about a 90 deg angle. Don't pull downwards as you might pull the metal away from the glass. Its much like pulling a bumper off - you just need to pull/push it hard enough .
There's a ridged bit of plastic that sits in a metal trough.
If you are not touching the upper arms, then you don't need to do this. There is no adjustment at these bolts."
As always the manual assumes you have experience as a Jaguar mechanic, and the manual just gives a blissfully simple description of what is needed to be done
" Remove the cowl vent screen starting at one side and working to the opposite side."
Regards Bill Dag
Regards Bill Dag
Zazzy (02-23-2019)
Regards Bill Dag
Regards Bill Dag
Mike
jimlombardi
11-09-2012 10:58 AM
Illini
05-07-2012 05:45 AM
eds123
09-24-2011 09:44 PM
