Replaced coolant pump and fitting at bottom of coolant overflow tank is leaking
Received 13,203 Likes
Hi ryejag,
Cracks in the tank are not uncommon. Also, the small hose nipple(s) on the top of the reservoir crack and leak coolant down the side of the reservoir and it drips off of the bottom near that lower hose.
You don't have the year and model of your Jag in your signature, but Rock Auto has aftermarket reservoirs starting at under $35.00, and they usually come with a new fluid level sender.
Cheers,
Don
Cheers,
Don
The following 4 users liked this post by Don B:
