Replacing rear suspension parts?
Lower shock bushes, and the anti-roll bar bushes also.
When we lowered the rear subframe on mine to put in the XKR-S anti-roll bar, got a hell of a shock at the old bar that came off the car.
The bar had rusted and thinned out under the bushes where it bolts to the subframe, the OD was reduced from 17mm to around 11-12mm, I don't think it was making noise, but certainly not working as it should...
B. I did a quick search and of course found an interesting thread that you started, this is the part you used? C2Z3523
C. As you know Cam I am doing more or less the same as the Swed, suspension overhaul, worth replacing mine?
Thank you guys for your answers.
My local Jaguar specialist told me they don't change the bushes anymore, just replace the whole arm(s).
I guess I'm trying to estimate the worst case scenario.
The car will have the front wheel hubs replaced on Friday and I hope my new discs and pads will arrive so they can be replaced at the same time. And I hope they have time to assess the rear suspenion.
I'm fixing the necessary things first, the wheel hubs and I'll take it slow from there. After all this is not the car I use daily.
A. What would be the benefit of switching the xkr bar?
B: https://www.jaguarforums.com/forum/w...-f-type-94044/
C: Honestly for the amount of effort involved in getting to the damn thing, maybe, maybe not. You have to lower the rear subframe, that's very labour intensive. But these things do wear out, both the bar and the bushes. Same for the front bar & bushes too.
Did you ever find out if it was possible to replace the rear bushings without dropping the sub frame? I noted the post in this thread that said his rear bar was really thinned down at the bushings and the one that said jaguar routinely changes both the bar and the bushings; fortunately I didn't see that on my front stabilizer bar when I did the front bushings - just wear in the bushings themselves.
BrentGardner
28
04-26-2024 03:08 AM
Fraser Mitchell
10-01-2015 04:06 AM
