Replacing throttle body
Installed my new TB today, very basic installation and was done within an hour. I still haven't received my new plug connector, 2 wire for the TB motor, so currently I have the bare pins connected to their correct location/orientation. I should have the new plugs (I ordered 3) tomorrow. I've started the vehicle after doing the simple calibration that cjd outlined in his post, worked perfect and the engine started, went to high idle and slowly came down as it normally would. I let the engine idle after that until the engine temperature reached its normal operating range. I then shut off the engine and restarted it and just a quick blip up to 1100 RPM and within a few seconds it setting down to normal idle speed. So I backed out of the driveway and took a quick spin. Throttle response seemed much better (could just be a placebo effect?) and no warning lights. So hopefully once I install the new wire connector I'll be rid of the dreaded "engine system fault" and DSC/ABS not available warnings. I will also add to all those that are having this problem, given how much less expensive the TB has become, if you think your TB is or has failed, install a new TB. I purchased mine at the dealer for $303.
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
KarimPA
09-03-2015 07:32 PM
davidladewig
09-03-2015 06:32 PM
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
