Reset Parking Sensors after Battery Disconnect
Hey all,
I just need some quick tech advice. The car dealer put a new battery put in my XJR the day that we bought the car. This messed with the parking sensors and it would do the 3 second long beep thing. As part of the deal of purchasing the car they had to send the car to Jaguar Dealer in order to do another upgrade as well and the Jaguar dealer simply did something to reset the parking sensors and they worked great again. Unfortunately, I had to disconnect the battery the other day and now the parking sensors don't work again. It just beeps when you put the car in Reverse or Drive every time.
Does anyone know this reset procedure??
Thanks,
D.J.
Thanks,
D.J.
I suspect you have got a mangled story re the sensor reset.
A 3 second beep means you have a failed sensor.
You can read the codes to determine which one or replace each sensor
in turn with a new one.
You can also try to listen to each one for a clicking noise and replace the one
not clicking.
not clicking.
The frustrating part is that I just got it back from Jaguar from this very problem. It was of course working perfectly until I disconnected the battery. And it only manifested itself the first time after the battery was replaced. I will try a few of the techniques to check them this weekend and try to pull the code.
D.J.
D.J.
trosty
26
12-18-2022 06:40 PM
