Resetting and updating gearbox software with IDS
#41
#42
Received 12,941 Likes
Since it would be prudent to change the rear main crankshaft oil seal while you're in there anyway, it doesn't really matter whether it's engine oil or transmission fluid.
Which makes me wonder about the coincidence of this happening just after all the work you've recently done... Is it possible the fluid just got splashed up there while you were draining the transmission and lowering the pan???
AD2014 (12-09-2019)
#45
#46
![Post](https://www.jaguarforums.com/forum/images/icons/icon1.gif)
At 64k kms owner reported burning oil odour---dealer replaced the rear crank seal AJ83744 and 5.3 hours of labour. Total $785
One month later, at 66k kms, owner reported oil leak under vehicle---dealer replaced transmission oil pump seal C2C6727,supplies and labour. Total $887
When I bought the car it had leaking transmission oil cooler lines---I am sure removing the transmission twice probably shortened their life--I got a $2000 price reduction and replaced the lines with new factory gear for $200.
#47
So have started the process of transmission removal. I am working with the car on jack stands and laying on my back on a cold concrete floor so I am pacing myself.
Anyway I will have to rotate the torque converter to get at the retaining bolts.
Question when facing the front of the car which way should I rotate the engine?
Will I be able to rotate the engine without taking spark plugs out?
#48
Heard horror stories..
#49
Just found this while looking for torque settings:
ZF6HP26
TRANSMISSION FLUID LEAK
COMPLAINT:
CAUSE:
CORRECTION:
The transmission appears to be leaking from the front seal (Refer to Figure 1).
The vent is routed to the bell-housing in a similar fashion as Ford’s 5R55S&W transmissions
and could be mistaken as a front seal leak should fluid be pushed out of the vent.
Check the fluid and level to determine if the transmission is either over filled, aerated or
overheated. If overfull, correct level.
So overfilling could have been the issue because during the fill process I messed around with the rear height, trying to level from side to side, of the car and had it higher than the front.
My level was inaccurate as well!!!!
In any case I want to look at some clutches so will proceed with dropping the transmission.
ZF6HP26
COMPLAINT:
CAUSE:
CORRECTION:
Don B (11-25-2019)
#50
Looks like a difference between the 26 and 28.
#51
Other than comparing the 6HP26 to the Ford 5R55S/W transmissions, which are known for problems, this is great news! I'm hopeful that the fluid you noticed came from the vent rather than the front seal.
Are you certain you want to drop the transmission now? I'd be tempted to set the fluid at the correct level and drive the car long enough to see if the leak has abated.
Cheers,
Don
#52
Hi John!
Cheers,
Don
Cheers,
Don
Will make up my mind once I have had my two cups of hot tea!
Don B (11-26-2019)
#53
#55
That has always worked fine for me.
The following 4 users liked this post by abonano:
#56
Cheers,
Don
The following 4 users liked this post by Don B:
#57
I agree with abonano - it's the vehicle that must be level, not the trans pan. ZF designed it under the assumption that the vehicle will be level on a lift while the transmission is being serviced. Since the X350 doesn't have a frame, per se, I use the door sills as my level reference.
Cheers,
Don
Cheers,
Don
Don B (11-27-2019)
#58
I am using the door sills.
I got as far as the basic fill yesterday and went to start the car and discovered I had the gear selector wrongly positioned after detaching it and then refitting it.
So now in the process of positioning it correctly which is proving a bit of a challenge.
Also my computer threw a wobbly yesterday. My motherboard gave up the ghost and I wasted quite a while trying to recover from that to no avail. I could not access
any of the hard drives no matter how they were connected on the board.
Now waiting for a new motherboard from Taiwan.
Using my wife's computer. What a hassle for many reasons!
knzwmn
35
03-07-2019 07:25 AM
carate
01-24-2015 11:13 AM
bookman
12-29-2014 11:03 AM
