Restore Gear Shift Knob?
This is more of a curiosity question. The gear shift knob on my 2006 XJ8 is badly cracked. Is there a way to remove the finish, restore the wood, and refinish it? I assume it's a lacquer coating? Here's a photo of the knob:
The reason I say this is a curiosity question is I have another knob on order (should be here in a few days), so it's being replaced. Even so, if this one could be restored, it would be a fun project, I think. Thanks for any help on this.
Okay. I should have just researched this. It's just lacquer on wood. It can be sanded off or chemicals can be used to slowly wipe it off. Mine is so bad that I can peel off sections without damaging the wood underneath. So, I plan to remove the lacquer, re-sand the knob, and re-lacquer it.
I think all of the gear shift knobs from the XJ8 just screw off. There's a silver bit below the knob, but that's a separate piece and does not need to be removed to get the wooden part off. I had to crank it a bit at first to get it going, but not too bad. I wasn't afraid I was going to break anything. But I am sure it had not been removed since being put on at the factory. Once lose, it just screwed off. And if you look at the ones for sale, they all just have the metal insert with the threads in the bottom.
I stripped and refinished the shift knob on my X308 (planning on doing the X350 as well sometime, looks like the one pictured). The clear coating was definitely not just lacquer, but some sort of heavy-duty polyurethane or clearcoat. Soaking in methylene chloride stripper eventually popped it loose, but it wasn't easy.
Hello
This is the OEM, optional, Daimler Gear Knob as it is described in Brochures for the X300:
I have it for sale on ebay:
https://www.ebay.de/itm/114898974669
