Retrofitting A Temperature Gauge that Works?
There was a guy on the XK section that made an accessory to force their temp gauge respond without the damping. But I don't know if that ever made it to the later models or would work on the x350.
Most people with the x350 use a bluetooth OBDII dongle and an app. You can get aftermarket temp displays to go with this.
The issue is the cluster programming. The PCM knows exactly what temperature the ECT sensor is reporting, and that data is on the CAN network to the cluster (the cluster is the network gateway for the car as well). But the cluster programming which controls the temp gauge is where the damped response comes from.
There are lots of shops that work on these Visteon clusters, mayone one of them can reprogram these to work the way we would prefer? I don't know if anyone has ever asked.
EsRay (09-28-2019)
paddyx350 (10-04-2019)
