Ruff/hard suspension
Hello!
I just bought a Jaguar XJ8 3.5 from 2005. I looks and go super! But there is one problem with the rear suspension. If i drive over bumps or a "pothole" its really a hard hit and it feels like the suspension is "bottom out". There is no problem with the ride high or any air suspension problem messages.
I now have found a test of the suspension from the last service and there it states that the left rear dampers "Suspensionsmeasurement" is only 0.07 mm. The right rear suspension has 0,30 mm.
See attach picture, the diagram is in Swedish but you guys mayby now whats wrong any way?
My question is if I need a new air strut (as i suspect) or is there something else on the suspension that can cause this problem?
Thx for the answer, will try to contact the shop that did the test. There is no leaning of the car to left and the ride hight is ok. If the struts is collapsed I tought the suspension will go all the way to the bottom and I would get a vehicle to low or air suspension error message?
Similar issue on my 2004 XJ8 that I purchased a few weeks back at a spectacular price. Noiced when I went over a speedbump with any speed faster than a crawl I'd hear a loud CLUNK as if the spare was bannging up and down in the trunk. Took it in and they determined that the ball joints were blown on the left and right side. the symptoms matched the dioagnosis and now im getting those replaced.
One of the two "balljoint" bushes in the lower rear wishbones wears out very quickly. Jaguar will only sell a complete wishbone, so you're into the aftermarket either for a half-price wishbone complete, or the bushes to replace. These bushes are not what you think of as a balljoint, they have a circular moulding or "ball" in the middle of the bush. Here is a typical item and price.
Jaguar X350 Rear Lower Wishbone Bush - Detailed item view - Jaguar Spares Northeast
And another, (price is for two)
Racing Green Jaguar. - Jaguar X350 XJ saloon 2003-2009, Wishbone bush, lower rear
The third bush is a Silentbloc type and lasts for ever, (or almost)
Or you can buy the complete wishbone off the internet: -
http://www.justjagsuk.com/product_de...r/6322/347688/
Jaguar X350 Wishbone - LH Rear Lower (C2C39586) - JustJagsUK.com
dmatthewman
09-30-2015 10:10 AM
