running lean??
if the car (2006 XJ8L 4.2) was running lean enough to set off the 02 sensor, would you feel it?? like a shaky idle or hesitate to accelerate? i kept getting a lean code in bank 1 #2 sensor, and put fuel injection cleaner in the tank twice and ran it a hundred or so miles at speed and the light has not come back on, but it never ran bad.. after clearing the code before the cleaner, just after a day or so the light would come back on.. after the cleaner so far it has been off for almost a week now.. still holding my breath..
Bigvettefreak (11-08-2015)
well so far, no light. and all i did was put another strong injector cleaner in the tank and run it a 200 miles. if there was an air leak, that would have triggered the light by now. i think i had a semi clogged injector on that bank that was leaning out, and putting in the cleaner back to back got it working again.. That is my hope at this point. it has always come on way before now..
Thank you for your help.
Bigvettefreak (11-11-2015)
where would the air leak be most likely?? the intake? fuel rail o rings or bad injector o rings??? the light stayed off for 2 weeks and after a long run and then sitting for a couple hours it came back on again plus fuel mileage was down on the return trip... This is nuts, plus it has already cost me a ton for parts and it still goes on.. i am running out of money to throw at this.. i love the car, but i may have to sell it.
Received 2,263 Likes
Bigvettefreak (11-19-2015)
