Running wires to the doors How?
Ive finished installing cameras in the folding mirrors.
Trying to work out where the wires go from the door through the rubber tube on the drivers side (RHD) into the cabin
I have interior kick panel out but the has a panel with a bunch of plugs on it. Looks like a pain to remove
Do I need to take out the inner wheel cover to get to it?
How have people run extra speaker wires into the doors?
34by151
34by151
Worked it out.
You have to remove the fuse box and pull the earth cable out of the way.
That gives somewhat limited access to the cable running to the door
To run the cable I didn’t pull out the flexible rubber tube that goes from the door to the body
What I did was to feed a cable the harness and through the tube. I then used this as a tail to pull the cable through
The cable I fed through initially was a 1/4 in flex cable. This is the inner core of the push/pull flex cables used for remote control planes
They are perfect for doing this stuff as they have a threaded internal section to mount clevis that you tie your cable to when pulling it back
cheers
34by151
cheers
34by151
99xk8guy
06-05-2023 06:28 AM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
philwarner
09-05-2015 10:05 AM
