Screen washers clogged?
Check the rubber hoses at the base of the arm at the attachment point to the pivot. Remove the hose connecting to the arm at the base of the windshield, and then apply washer. If you see fluid coming out then move to the arm itself. Remove the nut, remove arm and invert the arm assembly and check to make sure the hose isn't pinched in the spring or the spring pin.
Dan R (03-14-2018)
I made this thread -
https://www.jaguarforums.com/forum/x...sy-fix-182039/
Also make sure the lines to the washer nozzles aren't getting pinched by the wiper arms and restricting flow.
Dan R (03-14-2018)
I changed the cabin air filter as well. It was dirty with lots of leaves and dust at the bottom outside of the filter holder.
I will clean out the pump filter at some stage.
Sooner rather than later, the rubber boots on the upper control arms have rotted away!
car5car
05-18-2016 05:16 AM
