Sears Diehard Battery ? - FIXED
Old 10-07-2011, 02:40 PM
Received 2,263 Likes on 1,845 Posts
Best find out for sure. My car has the OEM alarm and can sit for months without the battery going dead. Did you try the trick I suggested up above about disconnecting the battery?
Old 10-07-2011, 02:52 PM
Cajuncat's Avatar
I don't double lock (press remote lock twice) my car. Does only one "press" cause the computer not to shut down .
It's still at the shop. I passed on disconnecting the battery. I'm not sure that's what they did.
Old 10-11-2011, 03:34 PM
Cajuncat's Avatar
Just picked up my Jag from the mechanic. Seems as though there was an inside rear light turned on. This was causing a slow drain on my battery.
I sure do hope this is the solution to my "dead" battery problem. It sure felt great to get behind the wheel
Old 10-12-2011, 03:51 AM
Cadillac's Avatar
Good to see you solved battery problems
Old 10-12-2011, 07:22 AM
limelight's Avatar
A light left on should have been easily picked up on with your previous battery draw tests. I hope they actually found the problem for you.
Old 10-17-2011, 10:21 AM
Cajuncat's Avatar
Hmmm my car alarm went off yesterday . I'm not sure if it's related to my battery problem I spoke to the shop this A.M. and they said they could disconnect my car alarm. Pls advise
Dagny
06-11-2024 01:06 PM
99xk8guy
05-28-2024 09:36 PM
JarodL
03-07-2024 01:39 AM
Guy-Pierre Boucher
09-16-2015 05:55 PM
jaguarbill
09-05-2015 11:43 AM
Quick Reply: Sears Diehard Battery ? - FIXED
