Seat Heaters Not Working
So it got cold in Fort Lauderdale, FL last week. That's anything below 65 degrees for us. I decided to turn on the heater for the driver's seat. The steering wheel got blazing hot, but on the seat, nothing.
So I sat in the passenger seat and turned on the seat heater. Again, nothing.
I didn't have time to try the rear seats.
Can anyone think of a reason why both front seat heaters wouldn't work while the steering wheel heater would even though they are interconnected?
Is there a separate fuse for the seat heaters versus the steering wheel?
Lagonia (01-09-2016)
Do the electric seat adjustment motors still work ? There is a listing of fuses in the Driver Handbook; have you looked in that ? There may be a relay as well, as the fairly high current needed to heat seats up would normally be switched with a relay. I think these are also in the same pages as the fuse lists.
Yeah, the seat adjustments work just fine. I'll do a further investigation when I get home on tomorrow.
If it is the PCB relays in the fusebox, then check the tail and reversing lights while hitting the brakes. If the relay has failed they will not be getting 12V properly, and may not be illuminating correctly.
In my case, the Jag dealership wanted ~$900 for the fusebox, so I bought one used, and replaced it myself. A reasonably simple task, it is located next to the spare tire The relay in question is built-in to the box so can't be replaced separately.
nlt624 (01-17-2016)
Thanks. I'm honestly thinking that I may trade this car in and go back to Infiniti. Last night I started the car and it immediately shut down. I tried this 3 times and same thing. Today, I go out and start the car and it starts and continues to run. I love this car, but after paying over $4500 in repairs 10 months i'm becoming frustrated.
